RadRom
Hi,
I want to make sure I have the correct control head sync file.
I have an XTL5K UHF-R1 with FW R20.50.10. Does this sync file Astro_25_CH_BR.cvn dated Jul 2016 match the injected FW 20.50.09/10?
XTL boots up. Error FL 01-90 then reboots into Maint. Mode. Neither the OEM USB-GCAI or the OEM USB to rear accessory cable will read/write the faulty radio.
So I need to use OEM RS232 to rear programming cable? (I have all 4 OEM programming cables for XTL's/PM1500)
Power connection, ground, TIB, 03 HHCH, cables, power to board/brick, etc all check out OK. From memory it needs a control head change in CPS and then a control head sync....
I don't wanna brick this thing ;-)
THANKYOU in advance.
