XTS 2500 CPS Issue
tgrahmann
Hello all, I recently purchased a Motorola XTS 2500 III (H46UCH9PW2BN) radio. I had an XTS 3000 a while back that I did not have the following issues with. When trying to read the radio with CPS, the following error appears: "This codeplug is an old development version codeplug. It is not compatible with this release."
If anyone has any insight on how to fix this, it would be much appreciated! Thanks!
rbrtklamp2
Dupage County, Illinois
What firmware is installed in your 2500. Also you cannot program a 2500 with the 3000 software. You need a copy of Astro25 CPS. Astro CPS will not program a 2500. Also the 2 models use separate programming cables as well.
Sent from my SM-N910V using Tapatalk
tgrahmann
You misunderstand me haha. I have purchased new programming cables and have acquired the proper CPS for XTS 2500 and XTS 5000 radios. That is the error I get using my new equipment. My FLASHcode is 501018-000488-8
tgrahmann
Where would I find that information on the XTS 2500?
rbrtklamp2
Put the radio into service mode by pushing the bottom button under the PTT five times immediately after powering the unit up
tgrahmann
The screen that appears says
1 CSQ
25 KHZ
rbrtklamp2
Oh wow its not showing a firmware version do yiu have the ability to update your host and DSP.?
rbrtklamp2
There should be a whole bunch of info that pops up it will go though your flashcode tell you it's a 8 Meg unit also the very first screens that pop up your host and DSP version.
tgrahmann
Haven't tried anything but getting CPS to read it yet. When I put it into service mode, it quickly flashes "SERVICE" then displays the CSQ and 25KHZ. Tuner reads it, and it'll read the FLASHport config, but nothing else.
rbrtklamp2
It looks like the firmware got wiped on it do you have a firmware file for it to do a upgrade?
tgrahmann
Ahh, I see what you're looking for, I've found the firmware version; it's R16.00.00 DSP version is 16.00.01
tgrahmann
All I have is CPS. I have a copy of ASTRO RSS. not sure if that helps any
rbrtklamp2
No send me a pm with your email address and we can go from there. I think I can help you but we can't discuss the tools needed on this site.
