XTS3000 XTS 3000 pulsing noise during Rx
swight
I use a Motorola XTS 3000 for work and after recently re-programming it there is a distinct pulsing noise that can be heard on all channels while receiving. I do not believe any radio-wide settings were changed but unfortunately I have been unable to test it on more than a few channels due to inactivity. It is definitely present on the 3 main channels that I use. All affected channels are on a half-duplex VHF system. I will attach a video of the issue. The excessive noise/static is only due to my distance from the particular repeater I was listening to during filming. If anyone has any suggestions or clues about what could be causing this issue I would appreciate the help.
IMG_5126.TRIM - Streamable
Mars_P25
Paid RR Supporter
Banned
The noise you’re referring to is priority scan sampling. Yes, it is annoying.
You may also wish to check the MDC DOS settings. You shouldn’t hear that annoying MDC braaaaaaaap.
Keep in mind if this is your work radio, whomever programmed it for you may have enabled priority scan sampling for a reason.
jjbond
Banned
Banned
Mars buddy? Is that you (Canada) ?????? How've you been hubby.... :)
