XTS 5000 concentric switch
P25Radio
Oceanside Ca.
Looking for someone to repair a concentric switch on a XTS 5000. Switch rotates but will not change from repeater mode to simplex.
GTR8000
NY/NJ Database Guy
BEE00
Yeah, I would first test the switch with a different function such as Tx Inhibit to rule out a programming issue vs a hardware issue.
Test it
Turn on radio
Press button above PTT 5 times until you see SERVICE
Press and hold purple top button then press orange button while still holding purple, icons will display
Release and you should see something like 3/0.
Now in button/knob/switch test mode, every change should generate a change on display
P25Radio
Oceanside Ca.
Checked the concentric switch with the options mentioned above, it will work in one position but not the other. You should feel a detent when switched, I do not.
P25Radio
Oceanside Ca.
Found the problem, I removed he volume knob and the dial for the channel indicator. I found that the plastic "NUB" for lack of a better name that sits in the groove of the concentric switch shaft groove was broken. The switch does in fact work fine. It was just a small broken plastic part. Now to find a part number for the concentric knob or just buy a junk radio and whore the part from it. Part is on order along with a channel number indicator. 4505375Z02 LEVER SECURE KNOB,CTR Thank you all!
