XTS 5000 red light blinking for absolutely no reason.
Mogley
Im confused as to why my xts 5000 red light seems to blink on its own for no apparent reason. Its a conventional analog channel. Channel is set to "Receive only" no one talking as I could confirm with another radio that absolutely nothing is going across the air. But for some reason the red light just seems to be blinking on its own has a mind of its own. Any ideas?
N1GTL
CT
You may be RXing interference that is not opening the PL. Remove the antenna while receiving and see if the light goes away. I have an HDMI cable leak in my house that will kill the RX on UHF.
WRTF671
Also make sure you're not scanning and don't realize it, I've seen that inquired here more than once...
chrismol1
P25 TruCking!
If you are sure the frequency is vacant at the time, low squelch and//or modern world RFI can cause red light to blink, non-voice or it thinks non-voice trans. If there is any secure selection on receive, that can also cause the light to flash on what it thinks is decode.
Mogley
Ok I did the pulling off the antenna trick. Seems to be random RF interference like the other guy mentioned about his cables causing it.
