XTS1500 Channel Capacity
K3RJS
Looking for some insight into channel capacity on XTS1500 1.5’s
Some that Im working on have a max channel capacity of 96 channels, while others have a max capacity of 256. These have differing flashcodes:
96 ch: 100001-000004-3
Q811(P25 Conventional),Q667(ADP)
256 ch: 500088-001488-3
Q574(9600Baud Trunking), G996(OTAP), Q947(Packet Data Interface)
Does anyone know offhand what feature is expanding channel capacity? I know with the XTL1500’s have G791 (enhanced software) which did the same thing, but does not appear to exist on this expanded XTS.
K3RJS
96 ch (UHFH): H66SDD9PW5BN
256 ch (7/800): H66UCD9PW5BN
N4DES
Retired 0598 Czar ÆS Ø
South FL
There was a channel capacity increases provided by a firmware update I think around 17.xx.xx that provided the increase in the 1.5 model. In the X series Moto provided it that way. Here's some previous examples...
R12.00.00 (May 2008)
- Windows VISTA with Service Pack 1 is now a supported operating system
- XTS 2500 support of Fireground Accountability software
- XTS 1500 support of ADP software encryption
- Enhanced Background Noise Suppression
- 3 field-programmable Mode (Pre-set) Select soft buttons
- Zone and Channel Up/Down buttons via soft buttons
- Encrypted POP25 via ASTRO Conventional
- POP25 feature is NOT supported with VISTA operating system
- Non-acknowledged ASTRO 25 IV&D data broadcast
- Advanced Conventional Key
- Additional channel support for XTS 5000/2500/1500 and MT 1500 radios
- Up to 1000 modes for XTS5000 (model 2&3)
- Up to 870 modes for XTS2500 (model 2&3)
- Up to 96 modes for XTS1500
- Up to 96 modes for MT1500
- Up to 32 modes for PR1500
- New replacement Vocon board for the Astro Spectra Plus
- Support for the Federal Signal siren/PA model SS2000-SM
- Mobile high deviation transmit
- Silent emergency support for the XTL1500
- 3 field-programmable Mode Select soft buttons
- Up to 1000 modes for XTL5000
- Up to 870 modes for XTL2500
- Up to 512 modes for XTL1500
- Up to 512 modes for PM1500
What FW level is in the UHF portable?
K3RJS
Ah, not sure how I forgot to check that initially!
96 ch/uhf: 17.00.02
256 ch/78: 20.00.05
Being as these are as old as they are (and in this case are being cleaned up and put into caches), I assume there probably isn’t any way to upgrade firmware on these anymore?
N4DES
South FL
A refresh dongle + updated FW would be the safest way. YMMV if you use the FlashZap method as not all features get updated.
How many UHF radios are you have to do?
K3RJS
Found a workaround in talking with some other people,
As long as you have an existing codeplug from a newer firmware radio (asuming flashcode matches), you can clone it to the older firmware radio with expanded channels and it will be stable. I was able to find a few in the stack with high enough firmware and clone across the entire allotment successfully
