XTS2500 ... PC not detecting connection
WA6IJD
Buckeye, AZ
Hello
A few weeks ago I installed Astro 25 CPS for my XTS2500. All worked well until a week ago. Now windows does not chime when the 2500 is connected. And of course will not show up under COM ports. Maybe 1 out of 20 tries it will chime up, then chime down. That's it. I have tried the radio and cable on my sons PC and works great.
I think the drivers are at fault. Maybe needing RDX ? Any help would be great. Thanks !
Windows 10
nokones
Sun City West, AZ
Hello
Windows 10
Which Astro 25 CPS are you trying to use with your XTS2500?
nokones
Sun City West, AZ
R20.01.00
That is the version release of a specific Astro 25 Portable or Mobile CPS Application. What I would like to know is which application of the Astro 25 CPS are you using? You're leaving out the main ingredient that is specific to the radio type. Is it the Astro 25 Portable CPS or the Astro 25 Mobile CPS. They are specific to either a portable or the mobile. For the XTS2500, you can only use the Astro 25 Portable CPS application for the XTS1500, XTS2500, and the XTS5000 portable type radios. The Astro 25 Mobile CPS application would be used for the XTL1500, XTL2500, and the XTL5000 Mobile type radios.
In other words, you cannot use the Portable application for the Mobile Type radios and you can not use the Mobile application for the Portable type radios.
nokones
Sun City West, AZ
With the CPS launched and the radio turned on and connected to the programming cable, go to the "File" pull down, and click on "Read Device", and you should get the "Select Port" box; you should see "USB" with a white background, click on "Ok"; are you getting an error saying "Radio is not detected from USB port?
If the radio is turned on, go through the steps again until to get to the "Select Port" pop-up, firmly squeeze the programming cable connector that is connected to the radio UDC side connector to ensure that it is making full contect with the necessary pin contacts between the radio and the cable connector, and then click on OK, keep the firmed squeeze on until you see the "Tree View" box pop-up and don't let up on the squeeze. If you let up, the radio will hate you forever and will die permanently and become a paper weight.
With some radios, the programming cable connector will not make a tight connection with the side UDC connector.
WA6IJD
Buckeye, AZ
Clean the side UDC contacts on the radio, and possibly the cable.
Did that again. Radio has same attitude. Chimes UP and then some random seconds later, chimes DOWN. Aggrivating. Still not reliable. I think its a driver issue.
nokones
Sun City West, AZ
If it was a driver issue you wouldn't have any communication at all between the radio and the computer. The problem is either at the UDC or the programming cable.
