XTS2500 w/ AES Preloaded Key
BigDogg795
Suffolk County, NY
I just wanted to verify before I do something that ends up costing me more money: I have an XTS2500 coming that has AES enabled with a preloaded key. If I used ASTRO25 to write to the radio it should not overwrite the key correct? Or am I stuck using FPP to ensure the key doesn't get deleted? There's no no trunking or other advanced programming; just basic simplex with encryption. Reading the radio, editing the CP and writing it back should do what I need it to or will I need a KVL to load another new key? Thanks in advance!
n3obl
Ø
PA
Im sure if it coming with a preloaded key it was probably programmed with infinite key retention.
You will need a KVL or other tools to load the key into other radios.
BigDogg795
Suffolk County, NY
That's fine, as long as the key doesn't get deleted when I write to the radio I'll be happy. When I had my XTS5K's they had ADP software and that was more than sufficient for my needs. I just don't want to have to sit there for hours programming three radios via FPP just to maintain the key haha. Thanks for the info!
prcguy
I re-write and reconfigure 2500s all the time and have never lost a key during the process.
chrismol1
P25 TruCking!
I don't believe hardware encryption touches the codeplug no? that only the encryption tool can talk with the encryption chip and it isn't bothered during normal CPS operation
n3obl
Ø
PA
If you accidentally uncheck the infinite key retention then loose power the key will be dumped.
KG7PBS
Sacramento CA
Hay stop don’t change the encryption tape from hardware to software. If you do that you will lose the AES-256 keys. I did that ones to play with ADP. Had to get the KVL to reload my AES key.
BigDogg795
Suffolk County, NY
Yep, wasn't planning on that lol. Part of the reason I bought these was the hardware encryption being enabled already! (not like I need this high of level of encryption anyway lmao!)
Awesome, I'll be sure to remember that, thanks!
