XTS3000 Xts3000 problem?
GearJammersc
SC
Got this today when i read my xts3000 what's this mean?
Ant9270
The Green Weenie
Invalid field under scan list one, Designated Data member option. Change it to none, or the channel of your preference. Otherwise, you won’t be able to write the radio.
GearJammersc
SC
I didn't see any invaild feilds no red indications. Nor did i see any under the the cps under invaild fields. If there were any invaild how could i write to the radio to begin with?
Ant9270
The Green Weenie
Just set the designated data member to none. You shouldn’t get that message again
y85csm
Electron Wrangler
Wrong side of the tracks
You clicked "Yes" to the popup. right??
It changed the setting to "none" for you.
Just program it back into the radio to clean it up.
GearJammersc
SC
I just used a saved code plug and all is well. I was just curious . I know the 3000s are old and can get a little dicey sometimes when there life expectancy is bout over.
ElevatorsAndRadios
yarewesog
SoCal
I got a similar message when I read from my Astro Saber, which to my understanding is a close relative to the XTS3000. I just clicked yes. Problem solved ^-^
