Xts5000 & cps issues
brian86
Maryland
Ok so i'm new to the confusing Astro CPS layout, I am use to Harris RPM. I acquired an XTS5000 MIII 7/800mhz Flashcode 589088-101683-7
I am trying to enter P25 trunking information in the CPS but everything is grayed out or it wont let me change the info.
What am I doing wrong is there a setting I may have missed? I have attached Screenshots.
Radio Info
Host R20.00.10
DSP R19.50.00
Tuning R01.00.05
brian86
Maryland
I don't trying to program receive only to see if i can get better reception then the old scanner. I ahve had no problems with the Harris radios in receive only mode, transmit disabled.
brian86
Maryland
so how does one go about coming up with a system key for monitoring a trunked radio system?
com501
An XTS5000 will instantly affiliate if you manage to program it with the system information, there is no way to disable it. Instant affiliate = instant disable by system controller on most systems if your ID is invalid.
There are methods around this but this is NOT for a novice programmer. Get help. LOTS of help, someone who has succesfully done this in the past. Posession of an unauthorized system key, BTW, if you manage to acquire one, is generally treated quite harshly by law enforcement and is a crime under the DMCA.
Good luck.
brian86
Maryland
Man this is some crap, I just want to monitor some talkgroups and I can't even do that. If someone could make a scanner that worked half decent without missing every other transmission I would buy one.
N4KVE
PALM BEACH, FLORIDA
Harris radios do not require system keys to do what you want to do. Motorola's do. The greyed area means you can't do anything there w/o the key. However, should you manage to get the key for a 5000, & the system manager "stings" it, the radio will be a "brick" and then an expensive paper weight. Some older radios can be set to affiliate on ptt only, and then you disable ptt, but on the 5000, it must auto affiliate, & then the system boss will see this & "sting" your radio, rendering it useless.
