I have an XTS5000 type III and an XTVA portable base with 50 watt linear. In theory I should just put the radio in and it will boost the 5 watt radio signal. But it doesn’t work. It’s a brand-new, old stock XTVA that was completely unused (kept in reserve) so there’s nothing wrong with it. But for some reason the XTS will not trigger the amplifier. When transmitting through the XTVA with the “PA” switch off, I read 5 watts into a dummy load. If I turn the PA on, I get 2.5 watts into the load. I do not get any amplification. I have removed the PA and hooked it up directly to the radio, powered it, and the same thing happens. 5 watts unplugged, 2.5 watts plugged in.
I tried the same test with a NOS Motorola N1274A linear I also have, same story except when plugged in I get close to zero watts out into the dummy load.
I have no idea why the RF from the HT isn’t triggering either of the linear amplifiers.
I have CPS and programmed the radio for HAM in a conventional personality. It seems to work fine, I talked to someone atop Pikes Peak on the rubber duck antenna, so it’s putting out signal.
Does anyone have any idea why the linears won’t trigger? Both are for VHF and I’m testing on 146.520, which is within their coverage.
Is there some CPS trick I’m missing?
I’d like not to have to spend a bunch sending the radio and XTVA to the Motorola shop if I can help it.
