XTS5000 Model 3
P25andstuff
I can't seem to find a straight answer on this question, Motorola says the xts-5000 model 3 has a 764-777, 794-806, 136-174 MHz 380-470 MHz 450-512 MHz range, but others have told me they only are 700-800mhz. I want to put in frequencies such as 461.075, 155.1075, 853.1859, and even use the xts 5000 as a amateur radio. Which is correct?
Will001
SC
The XTS5000 is a single-band radio only. For example, I own two XTS5K's: one of is a 136-174 model, and the other is a 700/800 model. To have those frequencies in a radio at once, you would need an APX8000 multiband radio. Any of the XTS-xxx models will only do one band at a time.
Mr_Boh
The Land of Pleasant Living
Just be careful on eBay, because a lot of listings have the model completely off - like a 7/800 model listed with the UHF model number. Try to search by H18QDH9PW7AN or by XTS5000 UHF. Then read in the listing to confirm the band split.
prcguy
Yes, many if not most have FPP these days. I think you want to look for Govt FPP over FCC FPP as FCC might require a dongle on the side of the radio to enable FPP where Govt is wide open.
Here is my UHF 380-470 XTS-2500 with a replacement brown case. This radio was Marine Corps contract so I thought it would be nice to retire it in a fun color. You can get replacement cases in many colors with new knobs for about $30.
Does the xts-2500 have a FPP
P25andstuff
Looking at a xts 3000 but it only has 800mhz, this is really hard on a budget trying to get a motorola that has low and high range.
Giddyuptd
Here and there
Did you have to adjust the rubber for the emergency? I had got one for a model 2 and ended up trimming the rubber as it would constantly press the button.
