XTS5000 selective call
adaw2821
I am trying to get selective call to work on P25 digital. I thought I had it set up in CPS but when I try it, it is being received on all radios. The receiving radio shows "call received" but then audio is heard on all radios not just the target radio. Under conventional personalities > astro call, I have all 7 boxes checked. I have the IDs all in the astro call list. What am I missing?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Check your squelch settings. Chances are you have Digital Squelch selected instead of normal squelch.
adaw2821
Thanks, I'll check that out tonight. Just to help me understand, why wouldn't digital squelch be selected since it is operating in digital p25 mode?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
The mode has nothing to do with the ASTRO Rx Unmute Rule. I suggest reading the help file in CPS which will explain all the choices.
adaw2821
There are squelch settings in both conventional personalities and under zone channels assignments. I've tried various combinations to no effect. I have been reading the help files which have been helpful in many cases but also leave some gaps in others (at least for someone new to P25).
Right now under zone channel assignment I have Rx squelch type set to CSQ and TX squelch set to FPL (I've tried disabling).
Under personalities > Astro > Rx unmute rule, I did have it set to normal squelch, although I think I've tried every combination.
I also can't get TMS messages to work and figure it related.
