XTS5000 SpeakerMic Problems
emtunderwood
Our department just acquired new old stock that has been aligned and tuned to factory specs and programmed accordingly. However, we were sent Noise Cancelling Speaker Mics. With the speaker mics connected the audio transmission is weak and garbled, upon disconnecting and using the mic on the radio, transmissions seem strong and clearer. Is their any fix for this or idea of what is going on to cause this?
Will001
SC
Is this happening on more than one mic? Also, I would go into the software and in the radio wide settings, unselect AGC for the external mic, and then set the gain to 6 or 9.
emtunderwood
It's happening on all the radios, especially what seems like low tx/rx power when connected.
Will001
SC
I’ve had the same issue before. Usually if I set the external mic gain to 6 or 9, it fixes the problem.
emtunderwood
So unselect the Analog/Digital/Securenet AGC for the external mic for both TX auto Control and RX audio control? What about noise suppression and Attenuation?
Thunderknight
Bletchley Park
Might they be "public safety speakermics", which have an antenna connector on the top of the mic? Not sure if the 5000's have it on the side or not, but if they do, a PS speaker mic will cause the antenna RF to be routed up to the mic. If you have no antenna connected to the mic, that could explain the system of "low tx/rx power"
(I know the 2500s require replacing the antenna with an adapter, but other types of radios have it on the side with a pin, hence my comment about not being familar with the 5000 type)
emtunderwood
They are actually RMN5066A MOTOROLA COMMANDER II SPEAKER MIC
