XTVA Power Question
RadioGuy3007
Hello,
I have a basic XTVA no Amplifier and I am wondering If I can hook it up to a cigarette lighter with a red and wire coming out of it. I have no access to the fire wall of the vehicle.
PACNWDude
I tried that once and it drew too many amps, even for just charging my radio. If you have an actual 12V DC power port it may work though, this really was plugging into the cigarette lighter which is usually less amperage.
brndnstffrd
CT
I agree with PACNW and say it really depends on the vehicle. While I have heard of it happening, I have never personally experienced an XTVA overdrawing a power port. I made up a plug specifically for this purpose for temporary installs using a fused K40 cigar power plug meant for a CB that i chopped the end off that connects to the radio and used the correct connector for the XTVA. It has worked fine in the vehicles it has been used in, however YMMV.
PJH
If it is going to be a permanent install, you will want to use a real power connection, preferably to the battery. Every vehicle that I have done installs in has some sort of passthru firewall. You can either use an existing one where the OEM wires are going thru or you can drill one (just remember to put a grommet in).
Also at this point you can install the ignition switch wire to prevent power drain while the radio is in there and the vehicle is off.
OEM fuses are 5amps on the XTVA
