I'm fairly new done plenty of research and stumped hard on this.... ft 840 EFLW 98.5 FT
COUNTERPOISE 14 FT not grounded. 1.5 swr on 10 meters no one can hear me. Voltage checks out 30 amp new power supply mic gain up. Z 100 plus tuner
any help is appreciated
It doesn't sound like there is any real problem with your setup. Yes, it would be nice if the tuner was right at the feed point, but that isn't always doable. 98.5' is a good length, assuming that you have a 9:1 transformer at the feed point. That length should be able to be used on 160-10 Meters with a local tuner. A SWR of 1.5:1 is not great, but usable. It shouldn't cause any damage to your radio. There will be some loss, but it shouldn't stop you from making a contact. I have worked with much much worse. As long as the meter on your radio is showing output power when you talk, you are getting something out.
There also shouldn't be any problem with using the power supply for both the radio and the tuner. The MFJ-4230mvp is a good power supply. A friend of mine used a MFJ-4245MV with his FT-991A, and all accessories, and never had any issues. Those supplies seem to have very low noise, even though they are switchers. I use a old ICOM PS-15 (analog) with my IC-735 and all my radio bench accessories. The accessories don't require a lot of power. Although, you might need a few ferrites to keep RF out of the accessories.
10 Meters can be a tough band sometimes. While propagation is generally good lately, that doesn't mean it is always good. During previous "propagation good times", I have worked cross country (Arizona to Maryland) while mobile using only 5 watts (HTX-100). What time of day are you trying to operate? 10 Meters is generally a daylight band. I have had my best luck during the afternoon to early evening. When the sun goes down, the band closes up. That's OK for me. I'm not a night owl anyway.
Sounds to me like you just need patience. I have had many times when I called CQ for hours, and never had a single contact. Other times it was like shooting fish in a barrel.
