Yaesu AD-2 diplexer
thesavo
Schenectady, NY
So, I picked up a Yeasu AD-2 VHF/UHF duplexer at a recent ham fest. I wanted to use it with a dual band antenna, 2m radio and a GMRS radio. However the rating say 400--450 mhz. Since GMRS is 462 /467 mhz, would that rule out this diplexer?
There is very little documentation on this accessory. It is only mentioned in a few Yeasu transceiver user guides.
Any insight would be appreciated.
Savo
AK9R
Staff member
Super Moderator
Central Indiana
Possibly. Diplexers are designed with a passband. If the passband on this one is 400-450 MHz, it may attenuate frequencies at 462-467 MHz.
BTW, it's Yaesu. ;)
thesavo
Schenectady, NY
ooh. i thought it looked right. so the pass-band on the UHF side starts to drop off over 450 MHZ. Thank you for that clarification; and the other thing. I always have a hard time with their name.
K9KLC
Southwest, IL
If you can get inside of it, you may be able to tweak around on it a little bit. I'd probably use a VNA of some sort. Even a Nano VNA would likely work to see what it's passing and what it's attenuating.
thesavo
Schenectady, NY
Ohh. May be a reason to purchase some trat equipment or ask a friend. These are great. Thanks
K9KLC
Southwest, IL
Honestly a Nano VNA is pretty cheap in the grand scheme of things and while I've checked many antennas, feedline and such many years without one, now that I have one I can't imagine life without one.
