Da Frog
I still have mine. Recently found an old copy of the service manual, too and I was able to peak it up a little. Mine always lost the memories when the power was disconnected. My buttons have become a little sticky over the years. I tried both of the published mods for opening up 25-60 MHz, neither worked. I turned the Aux jack phono plug on the back into a discriminator output, and these are fairly good radios for data reception. They had remarkably good 800 MHz performance for their day. Unusual filter shapes made these sort of unique receivers. Today, mine sounds really poor on the new narrowband FM land mobile signals. (The FM narrow filter is fairly wide). I've never been able to get good audio reception in the 460-461 band (buzzy), but they have nice audio everywhere else. Good Broadcast FM receiver, too. Quite "hot" on VHF land mobile (150-174), but less than stellar on VHF aero band. Decent on UHF mil-aero. I replaced the PL-259 antenna connector with a BNC or N, can't recall which. Very good on 200-220 FM and sideband systems.
More of a communications receiver than a scanner. They do the Yaesu "keeps going" scan thing after a brief delay, the numbers flash in sequence as a count down to scan resume. You can search between limits or any group of ten channels in the one of ten banks. 60-905 MHz frequency coverage, very continuous with no gaps or cuts (pre-cell ban radio). Outstanding receiver for wireless mikes, especially widerbanded FM UHF models. These were once popular receivers with the de-bugging crowd for that reason.
Radio does not fully squelch in AM and AM narrow modes, slight hiss remains, annoying. Great, detented tuning knob but volume and squelch rubber knob sleeves tend to develop slip with age. Great function on the built-in attenuator. Clock and timer functions. Cute digital S-meter, works well.
Superb single sideband reception performance, very narrow filters, too. But if my memory serves, SSB is not available across the entire frequency range. In SSB and AM Narrow will tune in 1 Khz or 100 Hz steps. Both USB and LSB available from the front panel, but it does offset +/- in SSB modes, think 70's, LOL. . In AM Wide and FM Narrow steps are 5, 10, 12.5 and 25 Khz, 100 Khz only in FM Wide. Crude priority feature. Annoying programming system.
My name label metal strip from the top of the display worked its way loose and was lost during a move. All metal chassis, these things were built like a tank and are easy to work on.
We had these running at very high speeds and acting like real scanners with real scan delay by using a Commodore 64 control package back in the day. We even wrote our own control programs and it was easy to do. These radios have a functioning CAT system interface, but I've never been able to get it up and running that way using modern IBM PC's. Its astounding seeing a FRG-9600 scanning at >35 channels a second. I guess because the CAT interface is based around the TTL standard and C64's used it, they were an ideal match with no level converters needed for the signalling.
Fun radio. What are they worth today? I guess, whatever someone will pay, LOL.
Happy Scanning! - Ted
