Welcome to the hobby!
If you are starting out, the FT-60 is the best. The VX-6 may be a bit more than what you need! The FT-60 is a work horse and is built solid and tough. Nothing against the VX-6,mind you, I just think the Ft-60 is simpler to operate. The best thing,which I recently discovered, is the availability of a 7.2 Volt 2500 Ma battery. Thats more than some commercial batteries. The radio will do 144/440 MHZ. amateur bands at 5 watts, as well as allowing you to monitor aircraft and the public safety bands on the 150/450/800 MHZ bands. CTCSS/DCS encode/decode standard. The price for the radio is a very respectable $189 new shipped from dealers like HRO or less than that for a good used one . The radio comes with the usual battery,charger, manual( very well written), antenna, and 10 hour wall charger.That is enough to get one started. Thats just my opinion on the subject. Good luck with whatever you get.
Manny
