n9upc
While yes Yaesu System Fusion (YSF) uses C4FM and FDMA along with P25 using C4FM and FDMA they are just slightly enough in difference that it makes them incompatible.
Remembers C4FM is FSK (freq Shift Keying) using two sets of audible tones in a + and - deviation from 0 hz. For YSF it uses 2700 Hz and 900 Hz while P25 uses 1800 Hz and 600 Hz. The formats also use the same Vocoder so I can see why people think it might be compatible.
Also to add to more of the "why does it not work question pool" look at the YSF digital formats. VW (voice wide) basically is 12.5Khz for deviation like current P25 transmissions. (Heck both even have a data rate at 9600 baud for voice!!!) In the DN (digital narrow) mode it is like dPMR (think NXDN or iDas conventional) it is 6.25 Khz in a 12.5 Khz path where one path is voice while the other is data with FEC and GPS data.
I have not had a chance to review or peel apart the data stream but I have to somewhat assume that it is different also in order not to infringe on patents.
Hope this answers some questions and does not create to many others.
