Yaesu VX-6R vs Wouxun KG-Q10H
DocentLuzuge
Exactly, & I’d bet that CCR uses a ZERO conversion direct receiver intermod sponge. The Yaesu any day wins.
Sorry to hijack this old thread.
No it does not. The KG-Q10H is a superhet radio like most of the Wouxun radios now sold.
N4KVE
PALM BEACH, FLORIDA
A rarity in today’s radio on a chip world. Even the original MD380 was superheat, but it’s cheaper to make a direct conversion radio, & most hams are cheap. OTOH, I would suggest any radio that can use the open GD77 CPS/FW. It adds numerous features, & programming is very intuitive vs the standard CCR CPS.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Between the two, I would choose Yaesu over Wouxun.
My choice is repurposed LMR gear. Much better build quality, much better accessory quality, much better battery options(capacity), much better receiver selectivity, much better display. Software just works. Same with the programming cables, they just work. If I really want FPP, they do that too(I don't). I've got an Anytone DMR portable and an IC-92AD I keep around, but hardly ever use. I've bought my gear used, for pennies on the dollar, and I invested money in batteries and accessories.
n1chu
Farmington, Connecticut
@KK7RQX
I've had a VX6R for many years, having purchased one not long after they were released. It has withstood the test of time and endurance all of these years and I continue to use it everyday. It faithfully works just like new and appears "kind of new" as I give it a good scrubbing every few months as it is waterproof to some extent (can't recall if it's IP66 or 67?).
After all this time my two original batteries still work fine. I have also purchased two other batteries about four years ago from eBay,(not OEM batteries) and they are beginning to fail/not hold a charge. An option (and by default) on the VX6R is it displays the battery voltage when you switch it on. A full charge will show about 8.2 volts and I'll usually swap out the battery when it's down to 7.4 volts or so (it'll still work fine, it's just my routine). My use of the radio is mostly receive for several hours, with maybe a combined TX time of 30 minutes a day. With this usage I change the battery after two or three days.
The thing I like the most about the VX6R is its durability. It's super rugged and has shown it's toughness on a number of falls to the ground over the years (e.g. while hiking). I mostly it a lot on 220 and as you must know it has low power only on that band, but it works fine for me working a repeater about 20 miles from my place.
The comment about needing to have a reference card in the field to make changes is spot on. I can only recall the few frequently used functions to use in the field as the keyboard use to configure the radio seems a bit complex.
I was surprised to see the KGQ10H sells for $220, not much less than the Yaesu. But here's the thing, I recently bought a Radtel RT470X (tri-band TX/RX with more RX bands) as a backup radio. It has a better quality build and function than I expected for $33 from Amazon.
So in summary, after my long winded comment, I'd suggest the Radtel instead of the KGQ10H and save yourself the cash. But if you want a super durable HT that'll last forever and has better specs, buy the VX6R.
Good luck!
Agreed, the Yeasu has a good track record. But the Wouxun hasn’t been around as long, so its track record is still to be determined. (I discount comparisons to other Wouxun handhelds which may have poorer track records because the 10q is new, and improvements over previous models are what attracts buyers. All manufacturers tout what’s new when there is a new offering.) One thing I find with the 10q is its display is useless in sunlight… unless I missed some setting relating to sunlight bleaching out the display… I never would have bought it had I known about not being able to see the display in sunlight.
