Yagi antenna for scanner
Florida
I just bought a used BC9000XLT and want to listen to vht fm broadcast radio stations. I can hardly pick up radio stations with the antenna that came with it. Does anyboby know of a short 3 element outdoor yagi antenna that will work with this scanner or am I expecting too much because it's a wideband scanner and not a 88 to 108 mhz band stereo receiver?
JDKelley
Just call me "Sparks." Or "Lucky."
Hammerspace
You may end up having to make something yourself for that band (although I could be wrong - it's happened before!) A Yagi is a directional antenna, so do you know where the radio transmitters are? Not the studios, the actual transmitter aerials themselves. Those are what you're going to need to point at.
There are plenty of works on designing antennae for the apt pupil, so the material is out there, and I don't recall the maths being overly onerous.
You may also want to look for RDF (Radio Direction Finding) antennae for DF contests, finding one for the 2 m band will be close to what you want to work with (broadcast FM runs 88-105 MHz or so, 2M runs about 145-150MHz, give or take. I'm not looking at a band plan right now.)
If you do not know where the station's transmitter aerial is, you may be better off using a discone with a vertical element protruding from the top (tune the vertical for the desired frequency band,) or a vertical 1/4- or 1/2-wave dipole to pick up what you want - tune the length for the middle of the band you want. If there is a primary station you want to listen to, then tune for that station (but, since stations have been known to move, better to tune for the middle of the band. Figure FMB for 88-104 MHz, so 104-88 = 16, 16/2=8, 88 + 8 = 96, tune for 96 MHz. Feed the dipole from the centre, the discone is fed from the bottom by CoAx - the jacket connects to the cone, the centre conductor connects to the disc and vertical element. For the discone, I'd tune the vertical for 1/4-wave at 96 MHz.
Antenna maths can be found here and at various locations online, there are also a number of references available for purchase, starting with the ARRL Antenna Book, available at Amazon for $70, shipped. I would not wish to deprive you of the chance to hone your Google-Fu. . . ;)
AK9R
Staff member
Super Moderator
Central Indiana
Back in the days when home stereo was popular, you could buy directional antennas specifically made for receiving FM broadcast. Those antennas may not be easy to find these days.
A Yagi antenna is tuned for one frequency. The FM broadcast band covers 88 to 108 MHz, so the antenna would need to be broad-banded. This is where log periodic antenna designs come into play. The classic home TV antennas are log periodics. For that matter, a TV antenna designed to cover VHF Low (channels 2-6, 54-88 MHz) and VHF High (channels 7-13, 174-216 MHz) would, most likely, include the FM broadcast band.
The classic dipole antenna made from twin-lead that was widely used for home stereo is somewhat directional. It will hear better off of the sides than off of the ends.
You can look up FM stations in the FCC's FM station database. That will tell you the transmitter location.
bearcatrp
Land of 10,000 taxes
A discone would probably do the trick. Can you put up a antenna outside your home? If so, it needs to be higher than your roof top.
dlwtrunked
Because of the wavelength of VHF FM broadcasts stations, "your definition of "short" may not be possible. Also, no where have I seen polarization of the signal mentioned. If you want maximum reception, that needs to be considered. Most FM broadcast stations are circularly polarized. (A few are horizontal only polarized.) A Yagi will only be vertical or horizontal polarized. Those and a discone will work but are not going to not be ideal.
If you really need 3 elements, you could chop off the front director and part of the boom. They are not 'short' though.
Some of the old TV antennas worked well on FM broadcast, since the lower VHF channels were stacked up just below the FM Broadcast band. If you can find one of those, it would work, but again, it won't be short.
But, I'd agree with AK9R, try making your own dipole first. It's easy to do, and will work way better than the stock antenna. Might be all you need.
D31245
FN42
Coincidentally this morning, I came across this FM broadcast band antenna maker in the U.K. ("The Aerial Shop" - Ron Smith Aerials) who is supposedly well regarded in audio circles.
(Ref: Audio Asylum Forum Post - Radio Road)
Some wild looking FM aerials: Circular 5 ron smith aerials galaxie antennas
Peter_SD911
Scan Sexy
Surfridge, CA.
That looks funky. . .
You want funky???
Try 'Homemade Cuban TV Antennas'...
That's some funky salsa made from 'whatever'.
JDKelley
Hammerspace
The Cuban antennae, however, make sense given the constraints they must work within. Oddities of materials due to exigent circumstances.
I'd like to see the maths that govern the dingus I commented on first, and the specs on it. . .
You want funky???
Hit_Factor
Saint Joseph, MI
Sound quality will be poor, especially if you listen to music.
I would buy a purpose built FM radio.
By mandating a short antenna you are asking for trouble. You can't cheat the physics behind an antenna made for specific band.
JDKelley
Hammerspace
Ayuh. If it weren't for physics and law enforcement, I'd be unstoppable!
headsense
Member - Learner Driver
If your looking for an out of the box solution as opposed to science and labor of your own then the common Asian supermarket sites a full of FM broadcast band antenna options. Any metal in the air outdoors is going to be signifcant improvement.
Example Ali Express - SignalPlus Communications Equipment Store - 1/2wave aluminium dipole + 10 metres of coax USD $ 59.00 free shipping to Cresent Beach, Flordia. includes boom mast and pole clamps so you jsut need a mast pole.
Granted shipping is higher for many Yagi options as they tend to make them with fixed elements not folding or removable but a little searching would turn up something in the similar price range I bet.
If thats going to double the total price of your intial scanner purchase then find and use or hack and use a VHF TV / VHF/UHF TV log periodic antenna from around the ways.
K2RNI
Kingman, AZ
I miss when Ramsey Electronics was a thing. They had this great 4 element yagi I used to use for my 10 watt pirate station, after upgrading from their 5/8 FM aerial.
