Yellowhead County system
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Hinton RCMP is still on PACS and can be scanned for now. They are set to migrate to AFRRCS by the end of May and will be encrypted at that time. I believe Yellowhead County Fire is on AFRRCS and should be in the clear.
They also have a multi-site MotoTRBO trunk system. It is operated by Yellowhead county
He will need a scanner capable of decoding DMR/MotoTRBO I believe it is a ‘connect plus’ network.
I don’t know the frequencies for the county owned system.
They also use TELUS Link PTT service as well(not scannable)
wheelerg
Ontario Canada
Thanks ... ok, I saw the Yellowhead County system but wasn’t sure if Hinton area supported any agencies using it. Thanks.
kayn1n32008
Sector 001
The VHF-TRBO system is not listed in the database. You will have to do some leg work and determine frequencies, LCN order, ColorCodes, and Talk Groups.
