You CAN get a decent ground plane in a jeep gladiator!
OhSixTJ
It’ll just cost you way too much money lol
I mounted my ham antenna to a fishbone full height tackle bed rack. I would’ve preferred a 36x36 piece of metal but all I could source here locally was 24x24. It should at least work a little better than the usual cowl mount stuff that’s available.
G6FGO
Chief of Grammar Police.
Gloucester, England
So what solution would you recommend? I ask because I have a 1977 Toyota Land Cruiser with a fiberglass roof and am looking for ideas.
On my fibreglass vehicles (and the 'bike) I use dual band aerials which do not rely on a ground plane. There are a few to choose from in the Diamond and Watson etc ranges.
W2JGA
I'm trying to figure something out for my 2023 Rubicon Diesel with the fiberglass top,
vagrant
ker-muhj-uhn
California
Indeed, if height is not an issue, the Diamond NR-770HB ( or the chrome version ) works very well for me. I use a second one low on the back corner of my SUV to handle APRS @5W. The other is connected to a Diamond motorized lift mounted to a luggage rack for the mobile radio.
merlin
DN32su
I had 6 meters on a Harley, a bit like HP bikes. The rod has to be a bit longer compared to a metal roof or deck lid.
2 and 70 MM would be a bit the same.
I never liked the compact-tennas, their performance hurts a bit.
G6FGO
Gloucester, England
Try it with a convertible! I have made a connection to the tow bar for mine, which works reasonably well. As the whole car is fibreglass, it isn't going to disrupt the radiation pattern too badly.
On my fibreglass saloon cars ( and one steel) I have used 'on glass aerials' which also work well with no ground plane and are a little higher up of course.
Look carefully lower right, it isn't obvious...
Top centre of the glass hatch....
AK9R
Central Indiana
OK, the second photo is a Reliant Scimitar. But, what is the first photo?
prcguy
2 meter/440
Ground plane requirements for that are not bad and I find a trunk lip mount on the hood hear the hinges works well. It also works OK for CB but my upper bed rail mount behind a rear wheel well works a little better. I've posted this picture a dozen times so here it is again.
1727446958268-jpeg.169899
