Zadig Driver / Multiple dongles
davejl2001
When using multiple dongles (Nooelec v5) on a Windows PC (Windows 11) do you need to install the Zadig driver for each dongle? Or just once?
PDXh0b0
Woodland, WA
Just once for same chipset, soo all the nooelecs and the rtl-sdr blogv3, if you get an rtl-sdr blog v4, you'll need to run it again for that chipset
davejl2001
I have been using Zadig 2.7 looking to upgrade to 2.8. Has anyone has issues with 2.8?
jhsands
Texarkana, Arkansas
I had an issue with dsdplus stating rtlsdr_v4.dll is missing. The answer is to install VC.
Powershell -> Run as administrator
Set-ExecutionPolicy Bypass -Scope Process -Force; [System.Net.ServicePointManager]::SecurityProtocol = [System.Net.ServicePointManager]::SecurityProtocol -bor 3072; iex ((New-Object System.Net.WebClient).DownloadString('https://vcredist.com/install.ps1'))
Credit to @PDXh0b0
