G4/G5 Unmatched model numbers
vocoder
Indiana
Has anyone else noticed that the model number on the sticker (under battery) is not always the same as the model number imported from the g4/g5?
We noticed that sometimes when the wrong or mismatched model number is used for a profile, the units do not operate well and have bugs.
When they are matched correctly, the units work well.
Why are the model numbers that are imported different from the sticker? Is this a phase 2 upgrade thing?
Uni1
Unication Representative
DFW Texas
I have not seen any negative results from the programming file not matching the model number. I always use the convert new model feature to keep things straight.
GXX64 is Phase I or II
GXX66 is Phase II
GXX67 is Phase II DMR Conventional
vocoder
Indiana
The model number on the sticker is different because?
Which one should be used to make a profile?
Uni1
DFW Texas
Just match your model number to the programming file. Model number shows when the pager is plugged in to the PC.
IAmSixNine
Dallas, TX
To answer your question.
Unication had an original model number with the Phase 1 units.
Phase 2 had a new model number.
IF a Phase 1 went back to factory for Phase 2 update the internal model number was changed to support Phase 2 in the CPS. They did not replace the sticker.
IF you are in doubt, go with the internal model number that you read when CPS reads the radio. That will always be the most accurate.
vocoder
Indiana
Ok
Thanks to all
That is what i had thought, phase 2 upgrades. We just had a bunch upgraded and noticed the number mismatch when they came back. We were confused at first because we couldnt find many on the list with 1401 in the model number.
