DSD Plus error when starting
bobruzzo
W1AV
Cranston, Rhode Island
Attached is a screen shot of the DSD event log when I start the program. I don't understand the error. I dont know how to correct it. I looked thru some log files in the DSD folder but found nothing. It could be that I copied the DSD folder from another PC and put it on my other PC on other side of room. The program works fine except for these errors. The only thing I notice is audio pretty garbled at times unlike SDS PLUS. I tried using DSD tune but keep getting errors so I gave up on that. Anyway if anyone knows how I ccan fix the errors on dsd log screen, great! I also cant find the "console log".
mmisk
Ottawa Canada
Perhaps you could post your startup batch files that will help.
Also how do you plan to use DSD, for control channel for example.
PDXh0b0
Woodland, WA
Dsdplus.networks if you open it up in a text editor and look at line 7 (unedited line 7 would be blank, did you add a network ?)
Dsd+ exe running, menu select misc , download latest base files, unzip with something like 7-zip(windows extractor is hit n miss) copy the files from each folder of the extracted dsdbasefiles.zip and paste them into the main dsdplus folder
Pretty easy fix, first error says one of the base files are outdated, go to MISC tab at top and at the bottom download base files to update the DLL and EXE basefiles in the folder you downloaded.
And there is an issue with a network entry format in the DSDPlus.networks file at line 7.
NOTE: @PDXh0b0 posted as I was typing.
seagravebuff60
Well Known MRRS Hater
New York State
As far as the . Networks file: Perhaps a rogue character or something is in the line.
Open the file; I recommend Notepad++, navigate to line 7, and see if something is missing or added by mistake. If you need help, post the line here, and ill see if I can help.
bobruzzo
W1AV
OK Here is the dsd networks file attached but I dont see anything wrong...also I did update the base files/dll and no change.
bobruzzo
W1AV
the startup batch files I use (on desktop as shortcuts) are "1R" and "FMP24-CC" But its been a LONG time since I originally set this all up and dont remember much about how to do all this again. I simply copied the DSDPlus folder from an older PC to my current one. It still works the way it always did except for those errors I get. And audio is garbled most of the time. But when I use SDR TRUNK the audio is much cleaner. I tried using DSD tune but i cant figure it out.
OK did that and it worked. But I still have those other base file errors. I downloaded the latest base files, unzipped and copied to the main sds folder. But no change.
It says see console log (1R-Log.txt) for more details, start it up and close it after it shows/logs the errors. Then open the log to look and see what files. Or, just copy all these files shown below.
cg
Connecticut
it tells you which is failed vs passed, really is fairly simple to determine which file is outdated
bobruzzo
W1AV
OK I looked at the log file and HERE are the problem files:
2023.12.22 16:55:45 File: rtlsdr_FC0012.dll NOT FOUND
2023.12.22 16:55:45 File: rtlsdr_V4.dll NOT FOUND
2023.12.22 16:55:45 File: sdrplay_api.dll FAIL
Now just copy them out of the Base File DLL folder into your DSD+ folder. Post #11 shows you those are all in there.
