My fault, I shouldn't have grouped the scanners I was talking about into this category, I made things confusing
No problem, I just want the OP to know that he just has to update his scanner and he will be good to go.
I believe the process is as below to update the scanner from the PSR800 help file .. the Whistler 1080 should be the same.
Firmware is the computer program that operates your GRECOM EZ Scan Digital Handheld trunking scanner. Updates to this CPU and DSP firmware may be made available to correct issues that were not previously discovered, or to add new functionality to your scanner. This page will guide you through the process of checking for and installing these updates.
Note: A connection to the Internet is required to check for and install firmware updates.
Checking for CPU Firmware updates:
To check for an available CPU Firmware update, your scanner must be connected to your computer. The Computer programming system must be able to get the current CPU firmware version from the radio to compare against any available updates.
To begin the CPU Firmware update process, follow these steps:
If your scanner is turned on, turn it off using the power button on the front panel.
If the USB cable is connected to the scanner, disconnect it from the PC/IF port.
While pressing the Menu key, Connect the USB cable to the PC/IF Port on the side of the radio. At this point you should see a display of the current boot and CPU versions followed by the CPU SW Upgrade prompt.
Select the "Check for CPU Firmware Updates" option from the Update menu.
Click on the "Check for Updates" button on the update screen. This process will get the current version of CPU firmware in the scanner, and check the Internet for the currently available CPU firmware version. Information about the need to update your scanner will appear just below the version information.
If you wish to update the firmware in your scanner, click in the Update My Scanner button. The computer programming application will retrieve the current version of the firmware from the Internet and then apply that update to your scanner.
When you have finished the update, click on the Done button.
Checking for DSP Firmware updates:
Connect the scanner to your computer using the USB cable supplied.
If your scanner is turned on, turn it off using the power button on the front panel. The computer should recognize the scanner's Micro-SD Card as a new drive. If an autorun screen appears, it may be closed.
Select the "Check for DSP Firmware Update" option from the Update Menu.
Click on the "Check for Updates" button on the update screen. This process will get the current version of DSP firmware from your scanner, and then check the Internet for the currently available DSP firmware version. Information about the need to update your scanner will appear just below the version information.
If you wish to update the firmware in your scanner, click in the Update My Scanner button. The computer programming application will retrieve the current version of the DSP firmware from the Internet and apply it to your scanner.
The firmware can be found here *select scanner radio and the cpu file ver 2.8 at the bottom ...
https://www.whistlergroup.com/usa/updates/ Or just use the UPDATE options in the WS-1080 software.
