Mike_Alpha
I've programmed a P25 system into the TRX-1 via EzyScan software but I'm getting a strange digital audio decoding issue. It decodes the audio but outputs the undecoded audio at the same time. This happens on all digital protocols. The scanner is running on the latest DSP and Firmware updates.
You can listen to the issue here - https://drive.google.com/open?id=0BymaK158-JamdTZjb3I3SnNjNWM
Is this a faulty scanner?
