ka3jjz
Wiki Admin Emeritus
We have a hole in the information for rebanding scanners - so far, no one has documented how to apply this for Home Patrol (via Sentinel, Power Patrol and ARC-Patrol), PSR-800 (using EZ-Scan), PSR-700 (I would assume EZ-Scan works here too) and the PRO-107 (via IScan).
I would assume that if the rebanding flag is set in the database that downloading the latest version would apply the necessary changes (and that's a fact that should be documented, if true), but what do you do if you need to put this in manually?
If you don't know how to put this together, give me a yell and I'll walk you through it.
best regards..Mike
[edit] I see fmon has detailed this using EZ Scan for the PSR800 in this thread - if someone were to take a screen shot or two this would be a good first step in getting this documented
GRE Forum - PSR-800 Trunked Frequencies
best regards..Mike
