DStar absolutely fits in a 6.25Khz channel. That's a FACT. Not sure where you got your belief that it does not, but you are not correctly informed.
Well, the older radios didn't; the Utah VHF Society tests he's referring to show that for the two radios they tested (Icom IC2200H and Icom IC-91A(D) ) the RF bandwidth for the GMSK modulated signals was between 7k and 9k
Some earlier DStar radios possibly could not tune in 6.25 increments, but they could be memory programmed to store the newer channels. I have four DStar radios and have not found a repeater that could not be programmed into memory.
As for testing. Really who cares. You have to be the first individual in three years (since I have been using DStar who brought up that issue. It apparently is not an issue with the vast majority of hams.
Only those that believe that a viable digital voice mode MUST have detailed diagnostic documentation published; since D-Star was designed first and foremost to encourage experimentation with digital voice and data technology, there is less of a need for that.
DStar is THE standard for amateur digital radio at this point whether you like it or not. Everything else is a distanced minority. That is a FACT as you like to point out. Sure you can play for P25, DMR, and all the other commercial stuff that does not work as well in the amateur radio market, but it still is a commercial standard with commercial technology for a commercial market. Amateur radio does not have talk groups, radio IDs. We have call signs and multiple radios.
Agreed; DMR (at least MotoTRBO) is too dependent on "approved" hardware and software to work well as an Amateur Radio system, though I think Mr. Rayfield might not like hearing that. The truth is, the more complex you make a system, the less it works as intended; it might seem to work well at first, but the nature of TDMA is actually working against those that use it in ham radio, at least as currently deployed.
So if you actually want to talk to someone, get a DStar capable radio. Tens of thousands of users. Close to 2,000 repeaters worldwide. Get some other digital commercial radio, and you'll hear the sound of crickets, but only if standing outside.
Yes, and you get a lot of choices in nets on D-Star; I believe there are nets on the various reflectors nearly every night of the week, whereas there are only two that I know of on the MotoTRBO World Wide system. Plus, some reflectors (mostly DExtra and DCS) have bridges to analog FM, Echolink and IRLP (I know this can be done on local talkgroups on DMR), but these are full time available to all users that connect to the reflector.
