Baofeng Base antenna for UV-5R
coachrork
I have a UV-5R as well. Is there a certain type of antenna mount I could get for my house? I mostly use it for FM radio and NOAA and I wanted to maximize my options. Thanks
ladn
The radio itself uses an SMA connector. The antenna mount will be dependent on what antenna you choose, but many "base" antennas do not require a mount and will bolt directly to a pole and connect to the coax feedline with a PL259 or N connector.
Be aware the UV-5R is very susceptible to receiver overload and an external antenna may bring in more signal than the radio can handle and you'll end up with reduced performance.
