Yep, those are the site frequencies, so they need to be unlocked no matter what you are looking for on the system.I see the top frequencies are unchecked. Those must be what the talkgroups go through. Didn't know that.
Just start a new log when you're away from the scanner & pc.forgot about the logs. just deleted all of them.
What is my next move if nothing comes up? They stopped operations at 6pm. Will start back up in the mourning. I will leave it running until I go to work. Been running over 15 min and nothing so far.Just start a new log when you're away from the scanner & pc.
I do also, its just the pats talkgroup I really want. Even have the railroad and other talkgroups.2020 I have no trouble picking up Paducah PD Mercy EMS Paducah Fire when in the area with my 325P2 996P2 436 536 SDS100 or SDS200
Just listen to your normal list, if you want, this evening. Then, tomorrow morning, switch to the modified, ID Search list & leave it running connector to your PC with ProScan also running.What is my next move if nothing comes up? They stopped operations at 6pm. Will start back up in the mourning. I will leave it running until I go to work. Been running over 15 min and nothing so far.
If you still do not get anything, try that conventional channel I linked earlier. If still nothing, then they may have switched to one of the other systems listed for your county. You'd set them up, one at a time, to run ID Search & see what you can spot.
This one has zero talkgroups listed, so either it is no longer on the air, or nobody has tried listening to it to see what it is carrying.
Sensing Communications Trunking System, Paducah, Kentucky
Sensing Communications Trunking System Profilewww.radioreference.com
This one shows to have the taxis, but if you don't find the buses anywhere else, I'd try it as well.
Jackson Purchase Two-Way Radio UHF Trunking System, Various, Kentucky
Jackson Purchase Two-Way Radio UHF Trunking System Profilewww.radioreference.com
To receive the MOTOTRBO system, you would have to purchase the DMR upgrade for the BCD325P2 if you do not have it. The upgrade already resides in the firmware. You would go to my.uniden.com, supply the proper information to register the scanner, and then purchase the key to enter into your scanner to enable the upgrade.
PAT is now using the Freedom Towers MotoTRBO trunked system WNYY415.
463.2250 LCN 1, 461.5250 LCN 2, 460.6750 LCN 3. Color Code 12
TG`s 205 and 206
I will look at it tomorrow on the road today and tonight
Glad it worked out for you. Since that were not using any of the systems listed for your area, it's no longer a puzzxle as to where they went. The Freedom Towers system is not listed in the database page for trunked systems in your state. If you can get more of the details for the system (frequencies, talkgroups, LCN'x, etc), please submit them to the database for future reference. Also, submit a correction that the transit agency is no longer using the Paducah Public Safety system.I finally figured it out no need to look at the tree I made. I used the site freq you had and found only one was needed. Both taxi and bus are fed through it. I would've never figured out this issue on my own. Had a hunch I had to buy a key but I didn't know what to do with if I did. Just glad a month if aggravation is over with. Once I heard a bus drivers voice I knew I found what I was looking for. Thanks for the input.
