falconair07
I'm the only Feed Provider for my county. USA>Iowa>Mills>"Mills County Sheriff, Fire and EMS."
They just switched to a digital system and I am having trouble programming my scanner so that I can continue to be a Feed Provider.
I'm Using FreeSCAN to program. I have my conventional frequencies loaded still, and trying to add the digital in FreeSCAN, I try the following:
File>Import>RadioReference Trunked; USA>IA>Mills>Iowa Statewide Interoperable Communications System. Then I select Underwood/Mills Co Simulcast, and various groups such as "Mills County," and Region # Interoperability groups, and Department of Public Safety Area # groups.
When I import, no issues (I suspect once imported I need to do some edits). When I upload to my scanner, there is 1 system, 14 groups, and 164 channels. I get the following errors: Unable to set WX, and No APCO band plan available for Underwood/MillsCo.
Other thread searches have comments such as "This is a known documented bug. Ignore it and move on" or "Not really a bug - APCO (P25) systems get the tables from the control channel, so not having tables on upload is normal." YouTube videos for setting this up haven't helped me.
Either way, it seems like my scanner is not receiving the traffic. Can anyone help me troubleshoot this so I can get me feed back online? Thanks in advance.
