BCD436HP
jonwienke
More Info Coming Soon!
VA
What frequencies are you listening to? That will determine the best antenna.
jonwienke
VA
Everything listed is UHF or VHF, so the Diamond RH77CA, at least for handheld use.
W8RMH
Feed Provider Since 2012
Comet CH-32 Miracle Baby, only 1.75 inches long. A dual band amateur antenna, I have been using, and recommending, these antennas for scanner use over 20 years. Great for handheld radios, easy to conceal, and not sticking you in the armpit.
The Diamond RH77CA is a good antenna but it's 15 inches long.
jonwienke
VA
The miracle baby and similar antennas perform poorly, especially on VHF. You're compromising reception performance severely when you shrink the overall size. Mini antennas like the baby are only usable in strong-signal environments.
GTR8000
NY/NJ Database Guy
BEE00
Where exactly do you see VHF listings for FDNY? It's all T-Band...they haven't used VHF in years.
GTR8000
NY/NJ Database Guy
BEE00
Everything listed for NYC. FDNY and police, etc.
OP specifically stated he wants to listen to FDNY; he did not mention NYPD or any other agencies. See also:
Looking to purchase a scanner to listen to the FDNY
jonwienke
VA
Not to be pedantic, but that doesn't change my antenna recommendation--the RH77CA. It's better than the Remtronix 800 for UHF, and the OP can use it to listen to public safety stuff other than FDNY if he takes a notion to do so. Or not, if he doesn't.
