N5RIV
I HAVE A BCD536HP SCANNER AND PURCHASED THE NXDN UPGRADE. I PROGRAM THE SCANNER USING THE SENTINEL SOFTWARE. I AM NOT RECEIVING THE NXDN SIGNALS. WHAT DO I NEED TO DO. THE MODULATION IS SET TO AUTO. THANKS FOR ANY ADVICE.
I think the caps lock issue is related to NXDN not working…Sorry about your broken caps lock key. That's a bummer.
The lone 536HP with a caps lock keyI think the caps lock issue is related to NXDN not working…
Or would that be "nxdn"?I think the caps lock issue is related to NXDN not working…
ConventionalIn addition to the above, you need to know the type of NXDN you are trying to receive. Is it Conventional or Trunked? Program accordingly.
I put in the nxdn code in to the radio and yes Sentinel shown nxdn and ran codesDid you install the upgrade or it came installed? Did you download the agency using NXDN from Sentinel?
Sentinel will show NXDN, Provoice and DMR regardless if you paid for the upgrades or not.put in the nxdn code in to the radio and yes Sentinel shown nxdn and ran codes
I too requested this info from the OP in post #3It would be best if you posted a link to the channel/s in question.
no I did not edit the favorite list after nSentinel will show NXDN, Provoice and DMR regardless if you paid for the upgrades or not.
If you downloaded something thru Sentinel, and it is NXDN, it should be working. Did you write to the scanner after appending in Sentinel? And can you locate the channel in question in the radio itself?
YOUR ASSISTANCE WAS SO HELPFUL ahSorry about your broken caps lock key. That's a bummer.
