Hratajesak78
I’m looking at getting the Bearcat SDS100. What would be the best antenna would you recommend to pick up the most activity?
Lots of folks, myself included, use the Remtronix REM-820s for 700-800-900mhz. In addition to improved performance, it has the nice sealed SMA connection that works with the SDS100
For 700-900 MHz you want the REM-820S. The REM-810S lacks the rubber O-ring to maintain water resistance.For 700~900 MHz the REM-810S:
I’m more interested to listen to the law enforcement, fire departments, and EMT. So which antenna would you recommend for that?Really depends on what you're looking to listen to. Lots of folks, myself included, use the Remtronix REM-820s for 700-800-900mhz. In addition to improved performance, it has the nice sealed SMA connection that works with the SDS100
Looking at your county in the database, a number or your local public safety agencies use Minnesota's ARMER trunked system. Additionally, the site in your city, Fargo, is Simulcast. The SDS100 is a good choice as it handles simulcast systems much better than most other scanners (other than its sibling, the SDS200). If everything you're interested in was on ARMER, then a gain antenna such as the REM-820S would do well. However, some of the smaller agencies appear to also use Vhf-high & Uhf conventional frequencies. Your adjacent counties in North Dakota also appear to mainly use Vhf as well.While the 820S is fairly decent on Uhf (I have a number of Uhf channels to deal with in my area), it's not good for Vhf. You would likely lose many of those channels. A better choice for the SDS100 would be the REM-842B. While not quite as sensitive on 700 & 800MHz, it still does well on those bands, It is also good on Vhf & Uhf. That's the antenna I use on my SDS100, and I also have a wide variety of frequencies in use in my metro area (DFW).I’m more interested to listen to the law enforcement, fire departments, and EMT. So which antenna would you recommend for that?
