Broadcastify Raspberry Pi Feed Appliance Image v1.0 (BETA)
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
Is Nooelec good, do you like theirs? I see they say, that they use Realtek SDR chips & not cheap knock offs. I am asking b/c RTL-SDR blog is sold out on Amazon with restock not expected till next month, if then. SDR must truly be all the rage, with the originators of SDR being sold out like this.
All I run is Nooelec SMArt and I think they are better in some respects than the blog dongle. Go for it. Just don't get the XTR version or the SMArTee versions unless you know what you are doing.
AB5ID
Lee's Summit, MO (Kansas City)
I've using the Nooelec NESDR SMArt v4 SDR with 0.5ppm tcxo for a year now, it has been rock solid running 24-7 with OP25. Only issue was initial physical seating issues with the USB connector.
jodfie
Savannah,GA
i also am excited about this! i would like to place my nod towards a Docker version as well as a Raspian OS 64Bit version is definitely needed for instance SDRTrunk could then be installed as well...
Is this hosted on a Git somewhere?
blantonl
Founder and CEO
Staff member
Super Moderator
San Antonio, Whitefish, New Orleans
Folks,
An update has been released to fix the soundcard enumeration problem for Raspberry Pi 3B+ and below models. You can install the update in the BCFY Shell by choosing option 9 (Check for Updates) and following the instructions.
pagerman0219
Racine, WI
I have DarkIce setup and running for feeds 1 & 2. I'm trying to configure 3 & 4 and I get this every time:
Enter feed ID to Configure for Darkice [34420] or [q]uit: 34420
>>>>>>>> Configuring: Mt Pleasant/Caledonia/Sturtevant Police
Configuration Written.
Do you want to connfigure this darkice instance to start on boot? [Y/n]: y
>>> Enabling darkice_4 to start on boot
Failed to enable unit: Unit file darkice_4.service does not exist.
Done. Press [Enter] to continue...
Configuration Finished!
Do you want to start this darkice broadcast now? [N/y]: y
Starting darkice_4...
Failed to start darkice_4.service: Unit darkice_4.service not found.
Unit darkice_4.service could not be found.
Press [Enter] to return to the main menu...
Help!
blantonl
Founder and CEO
Staff member
Super Moderator
Help!
I'm looking into this - stay tuned.
blantonl
Founder and CEO
Staff member
Super Moderator
Help!
I've released a quick fix for this (BCFY Shell v1.02)
Go ahead and update your BCFY Shell (option 9 - check for updates)
pagerman0219
Racine, WI
Still not working. Won't start:
Enter Soundcard Card ID to use for this broadcast: [3] or [q]uit: 5
>>>>>>>> Configuring Card ID 5
Enter Broadcastify Username:
Enter Broadcastify Password:
Retrieving Feeds for ...done.
Your Broadcastify Audio Feeds:
Feed ID Feed Description
[34420] Mt Pleasant/Caledonia/Sturtevant Police
[34452] Racine County Sheriff
[34528] Racine/South Shore Fire Dispatch
>>> Enabling darkice_3 to start on boot
Starting darkice_3...
● darkice_3.service - Darkice Instance 3 Service
Loaded: loaded (/etc/systemd/system/darkice_3.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Mon 2021-04-19 17:47:58 CDT; 1s ago
Process: 1146 ExecStartPre=/bin/sleep 10 (code=exited, status=0/SUCCESS)
Process: 1147 ExecStart=/usr/bin/sh -c /usr/local/bin/darkice -v5 -c /home/pi/bcfy/configs/darkice/darkice_3.cfg > /home/pi/bcfy/logs/darkice_3.log 2>&1 (code=exited, status=255/EXCEPTION)
Main PID: 1147 (code=exited, status=255/EXCEPTION)
pagerman0219
Racine, WI
pagerman0219
Racine, WI
>>> Configured Darkice Instances <<<
Item Status Config Instance
Boot
[1] active (running) Configured 1-Racine/South Shore Fire Dispatch
enabled
[2] active (running) Configured 2-Racine County Sheriff
enabled
[3] activating (start-pre) Configured 3-Mt Pleasant/Caledonia/Sturtevant Police
enabled
[4] inactive (dead) Configured 4-Mt Pleasant/Caledonia/Sturtevant Police
>>> Trunk Recorder Instances <<<
Item Status Instance
Boot
[5] inactive (dead) Trunk Recorder Instance #1
disabled
blantonl
Founder and CEO
Staff member
Super Moderator
You need to reconfigure the items from scratch so the updated services files get installed. Just re-run the darkice configuration for each feed not working properly.
pagerman0219
Racine, WI
also, check your darkice log files for more details in:
Code:
/home/pi/bcfy/logs
DarkIce 1.4 live audio streamer, Google Code Archive - Long-term storage for Google Code Project Hosting.
Copyright (c) 2000-2007, Tyrell Hungary, Tyrell Hungary Corporation
Copyright (c) 2008-2013, Akos Maroy and Rafael Diniz
This is free software, and you are welcome to redistribute it
under the terms of The GNU General Public License version 3 or
any later version.
Using config file: /home/pi/bcfy/configs/darkice/darkice_3.cfg
19-Apr-2021 18:29:27 Using ALSA DSP input device: plughw:3,0
19-Apr-2021 18:29:27 buffer size: 441000
19-Apr-2021 18:29:27 encoding
19-Apr-2021 18:29:27 Using POSIX real-time scheduling, priority 4
DarkIce: DarkIce.cpp:1272: can't open connector [0]
19-Apr-2021 18:29:27 HTTP/1.0 200
blantonl
Founder and CEO
Staff member
Super Moderator
Looks like there might be a problem with more than 2 feeds right now and USB problems on some Pi models. I'm investigating. What model of Pi are you using?
If you want to clean all configs there is a script to do so. It resets the image back to default.
Code:
sudo /home/pi/bcfy/scripts/clean_pi.sh
blantonl
Founder and CEO
Staff member
Super Moderator
Here is a fix for more than 2 feeds.
Add the following bold entry to /boot/cmdline.txt at the location below
dwc_otg.speed=1
Code:
sudo vi /boot/cmdline.txt
console=serial0,115200 dwc_otg.speed=1 console=tty1 root=PARTUUID=a8e0410b-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
pagerman0219
Racine, WI
Code:
Pi 4B
pagerman0219
Racine, WI
dwc_otg.speed=1
Code:
Trying this now
pagerman0219
Racine, WI
Still only 2. But a different 2:
Boot
[1] activating (auto-restart) Configured 1-Racine/South Shore Fire Dispatch
enabled
enabled
[3] active (running) Configured 3-Mt Pleasant/Caledonia/Sturtevant Police
enabled
Boot
disabled
pagerman0219
Racine, WI
dwc_otg.speed=1
Code:
any later version.
Using config file: /home/pi/bcfy/configs/darkice/darkice_1.cfg
19-Apr-2021 18:53:07 Using ALSA DSP input device: plughw:3,0
19-Apr-2021 18:53:07 buffer size: 441000
19-Apr-2021 18:53:07 encoding
19-Apr-2021 18:53:07 Using POSIX real-time scheduling, priority 4
19-Apr-2021 18:53:07 HTTP/1.0 200
