Cap+ Channel Priority?
Jentry
Dubai UAE
Hi Everyone!,
Does anyone here know if Motorola Capacity Plus Single site or Multi site can be programmed to have priority channels? What I mean about priority Channels is that even if the time slot if full, the higher priority it will supersede the lowest one to be able to use time slot.
Or can I program a CAP+ system that can reserve slots for higher priority Ch?
Brad_M0JXR
Bristol
I do not believe it can do this , except in the case of ALL Call .
You can use tx interrupt but if I read your question correctly you are looking for an order of preference being given to a specific Talk group .
I would also be interested in this , if possible .
As a rule of thumb I always suggest a good erlang ratio so Timeslots are never over utilised . Always suggest the N+1 method where Talkgroups are kept to absolute , so no priority is required .The N+1 where +1 will be the all call (255)use .
In design the Cap+ is the replacement for commercial community repeaters where no priority was a given - unfortunately .
