SDS100/SDS200: Conventional Discovery
tweiss3
Is it time for Coffee?
Ohio
I've found a 5 site system on the FCC registry that I have a short window to be within range. Emissions designator indicates it is DMR. Is there a way to run discovery on all 5 at the same time in conventional? The step is non standard, as the frequencies are .2875, .325, .375, 4875 & .5625
tweiss3
Ohio
You are right, 12.5kHz it is, I missed my conversion by 1 decimal place and thought it was 3.75, not 37.5. Again, remember, always check units and conversions. :ROFLMAO:
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
License you provided me appears to be 4 separate sites with one or two conventional (assumed DMR) frequencies each. I'd program them all conventionally, maybe create separate departments for each site, your call. Set audio type as "digital only" per frequency if you're certain they're all DMR. If color codes are unknown, set "Digital code option" to "Search" and it should detect the CC(s). Hope this helps
hiegtx
Dallas, TX
You can't run a Discovery session on more than one site at a time. What you could do, however, is put all of the frequencies into a One Frequency Trunked DMR system. Enter each frequency as a separate 'site', set for color code search. Set the system to ID Search, and (preferably) include a Department with a dummy TGID.
Set the scanner to record everything, and let it run as long as possible. Once you end your test run, & discontinue recording, review your audio files via the Universal Scanner Audio Player. If you see a specific talkgroup coming up on one or more frequencies (at different locations), and the recordings indicate it's the same usage, that would suggest a system. It would also suggest a system if you see that TGID being used on two different frequencies, that are at the same location. The audio player would let you see color code(s) used, slot used, as well as hearing the conversations. If, at a location where there are two or more licensed frequencies, you see a specific TGID only popping up on one of the frequencies, and always the same Slot number, that would suggest that these are being used as conventional DMR, a true trunked system. But as already discussed in other threads, in order to utilize TGID & SLot as part of your programming, you have to program the Uniden scanners using an OFT system, not just as conventional.
As John has already suggested, you could just program them as conventional, but unless you are using a logging program, such as ProScan, conventional will not give you a clear indication as to talkgroup & slots being used.
