- Joined
- Aug 19, 2014
- Messages
- 109
relatively new to HF, everything i've done so far has been FT8, and i was super proud of the 20m dipole i built... until a branch fell and did epic damage to my house and took out my dipole in the process...
my MFJ tuner couldn't get my 20m dipole to work 6m, so my plan once the roof is repaired is to make a fan dipole, 20m/6m... because i was able to use the tuner to do 80m, 60m, 40m, 30m, 20m, 17m, 15m, and 10m... when i add some legs for 6m i should be well set up...
and then i started thinking about 160m... i've never been able to tune that...
space is limited, but i've seen some interesting builds where i could use 450ohm window line to make a 40m dipole.
SO - my questions for the experienced operators and antenna builders...
1: will adding 6m legs to my DXE-MC20-1-1T balun that i will use to rebuild the 20m dipole impact my ability to use the 20m dipole on all the bands i was able to get to before with my tuner?
2: will adding the 40m 'linear loaded' legs impact the 20m dipole on all the bands i was able to get to before with my tuner?
3: in the example i found from ARRL (shown below), he's using less length of window line for 40m than i would be using of 12ga stranded for 20m... would it be better to double that length, cut and tune for 80m, and hope the tuner can tune that to 160m?
4: if not a 40m what non-resonant dipoles should i be able to get to 160m with a tuner?
thanks for any input... if the tree that dropped the branch hadnt had to be removed i would have considered an octopus for all this, because it would have hidden it from the neighbors enough for me to get by with the HOA... but now that it's gone, my best options are simple wire dipoles to not attract too much attention.
example of what i was going to add to my balun with 20m and 6m as a fan dipole: http://www.arrl.org/files/file/Technology/tis/info/pdf/0207040.pdf
Richard
N0TZC
Richard
N0TZC
