DMR Motorola Capacity Plus Multi Site
anthonyramos01
I am not sure if I programmed my BCD436HP correctly, but I have programmed a DMR Motorola Capacity Plus Multi Site to my scanner and the audio is scrambled. Is it some type of encryption.
This is a link to the system I programmed Intermountain Communications(DMR) Trunking System, Emmett, Idaho.
I have it set as a MotoTRBO Trunk
Natrona Heights, Pennsylvania
Hi, Welcome to RR. Nice find. It seems to be a new addition to RR in 2022. Not much TG info, maybe you could help build it out with submissions of what you find. Here is the WIKI for it https://wiki.radioreference.com/index.php/Intermountain_Communications(DMR) .
If you use your zip Code to program your radio this system should be available as it is already in RR. Once its in your radio change the setting from SCAN to SEARCH in SYSTEM OPTIONS for this system. So you can find more Talk Groups. You mentioned Scrambled or Encryption. IT could be the two TG's maybe Encrypted and that's why its not being built out. You might have to listen to this for some time to make a decision if its worth listening to it or not.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
