Dsd fastlane
cg
Connecticut
IF your system shows the LRRP lines in the Event Log window, then you can run the LRRP program which is a separate exe file. It will then show a map in a new window and plot the unit locations as they transmit to the system.
If your system does not show those LRRP lines in the Event Log window, then the data is not being transmitted for that system.
chris
Forts
Ontario, Canada
More than likely your system isn't using it. Many systems use other proprietary vendors for GPS etc that DSD+ doesn't recognize.
