DSDPlus DSDPlus 2.444 available
maus92
OCMD
2.444 works fine for me, and I rarely use the program. I did have to update the base files. One of the best troubleshooting procedures I've learned is to test on a basic / default setup, get that working, then add complication. As for not changing anything on the PC "for ages" implies no security updates to the OS have been applied. The security engineer's side of me SMH when I hear this, lol.
I use a simple batch file to automate things, but here it is for reference:
@Echo off
start FMP24 -rc -o20001 -g25.4 -P-0.1 -f858.4625
timeout 3
start DSDPlus -rc -i20001 -v1 -E -O NUL >>CC.log
timeout 3
start FMP24 -rv -o20002 -g25.4 -P-0.1
timeout 3
start DSDPlus -rv -Pwav -i20002 -v3 >>VC.log
timeout 3
The OP's "P" parameter value seems inordinately high.
LimaZulu
Well, the software engineer side of me has learned me "a few" things to keep my computer in good and working condition :)
Ok, let's simplify things and say that between the time when everything was working and the time the update came and I tried two dongle setup - nothing has changed :)
I do agree that when you test something you start from basics. That's why I stated multiple times that I already did that :)
Thanks to everyone who tried to help. I do appreciate your ideas and time taken. Unfortunately the problem remains unsolved so far. Please if you have any suggestions that haven't been mentioned, do it. But please take a look at what was done so far in order to keep the thread clean and not repeating ourselves over and over again :)
HE9JYP
Switzerland
The version 2.444 doesnt work for me (Windows 11) , but if I replace with 2.395, all is OK, no missing files...
*** LOG ****
DSD+ 2.444
Current working directory is "C:\DSDPlus"
DSDPlus -h for help summary
Appending synthesized audio to file 'VC-DSDPlus.wav'
Assuming FMPA/FMPP/FMP24 is signal source; auto polarity detect is disabled
audio output device #1 = 'Haut-parleurs (Realtek(R) Audio'
audio output device #2 = 'CABLE Input (VB-Audio Virtual C'
audio output device #3 = 'Haut-parleurs (4- USB Audio COD'
audio output device #4 = 'Haut-parleurs (2- USB AUDIO CO'
audio output device #2 (CABLE Input (VB-Audio Virtual C) initialized
Testing Base Files:
File: FMP24.exe FAIL
File: FMPA.exe FAIL
File: FMPP.exe FAIL
File: FMP-Map.exe PASS
File: LRRP.exe FAIL
File: Survey.exe PASS
File: airspy.dll FAIL
File: lame_enc.dll PASS
File: libfftw3f-3.dll PASS
File: libusb-1.0.dll PASS
File: msvcr90.dll NOT FOUND
File: msvcr100.dll PASS
File: msvcrt.dll PASS
File: pthreadVCE2.dll PASS
File: rtlsdr.dll PASS
File: rtlsdr_FC0012.dll NOT FOUND
File: rtlsdr_V4.dll NOT FOUND
File: sdrplay_api.dll FAIL
18 files checked
9 files passed
6 files failed (outdated or corrupted)
3 files not found
Base files test: 9 files passed; 6 files failed (outdated or corrupted); 3 files not found
maus92
OCMD
After doing the above, there should be a folder within the C:\DSDPlus directory called DSDBaseFiles. Within that folder is a subfolder named Executables. There you will find the current version of the files that were marked FAILED. Similarly, the FAILED dlls will be found in the DLLS subdirectory. Simply copy the newest files to the main \DSDPlus directory. This will overwrite the outdated versions, and you should be good to go.
slicerwizard
Toronto, Ontario
Indeed. I would start by only running the VC FMP24 instance and see if it responds to voice tuning cues. Manually create/delete that file you mentioned prior (NEXEDGE48_L1115-1_0001_167.593750_GC_104_3582.traffic) and see if VC FMP24 responds by flipping between tuning to 167.59375 MHz and idling. If it does, build on that. If it doesn't, well, cross that bridge when you get there...
peluson
Hello, does anyone know how to fix the error that appears in the red line
You need to find the line and entry (it looks like four in your case) and correct whatever you have missing or in a format not correct for them. DSD+ is talking about items in your frequency/site/network files, you would have to provide the rest of the message from the screen or 1R-DSDPlus.event for us to help more.
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
2.448 is available...
I cannot understand which kind of system is this. It looks like a normal BS but the TG's er not the usual ones.
Group call; TG=13-1072 ch27
Group call; TG=1-1668 ch28
TXI Group call; TG=11 RID=8777 Slot=1
Is there a manual for DSD+ fastlane ?
According to Google Motorola MOTOTRBO Transmit Interrupt shown as a TXI Group Call in DSD+ FL is a feature designed for their digital two-way radios. It allows for prioritized communication in critical situations. Here's how it works:
  • Interrupting conversations: TXI enables designated radios to break into ongoing calls on a channel. This is particularly useful for emergencies or urgent broadcasts that need to reach everyone immediately.
  • Delivering critical messages: TXI can be used for various methods of prioritized communication besides voice interrupt. Examples include remote voice dekey (activating a radio with a specific code) and other interrupt features.
Overall, TXI enhances communication control within a MOTOTRBO system by ensuring important messages get through even during busy channel use.
