wenzeslaus
- Joined
- Aug 30, 2023
- Messages
- 149
- Reaction score
- 64
KA-450 looks analog. same features, smaller size.
If your radio can use a USB port, then one idea is the one I posted earlier, A Ryobi 18 volt inverter / charger with a good sized solar panel and several) batteries, I use mine (it has USB and 120 volt outlets) to power a (6 watt) light for reading), I got tired of wearing head lights.I will keep the radio I already have. I will test how long the batteries will last The radio requires 4 AA batteries. I will keep looking for a battery solution to charge other stuff and I would like to be able to recharge the battery with solar panel if I need to. I like Bluetti but their solar panels are not really made for Canadian climate. I think their battery can work with third party panels but I will send them an email to make sure. Do any of you know of a good brand for solar panels ?
This.I try not to overthink it. I have a small AM/FM pocket type radio that runs on 2AA batteries. If I just listen to the news a few times a day those batteries will last me for weeks. Then I keep a good stock of spare batteries and I'm all set. I gave up on having SW radio since there's almost no real broadcasts on it anymore. The AM radio stations have good wide area range so I just work with that.
instead of taking all that time to burn through a set of batteries, why not just measure the power your radio uses?I will keep the radio I already have. I will test how long the batteries will last The radio requires 4 AA batteries.
A very universal little "emergency" radio is the LiJiANi Rd239.Hello all.
There are some new threads about emergency preparedness/emcomms going on. It made me thinks about radio options just to get the news and what the hell is going on. I have a Grundig/Eton satellite radio that is AC or battery powered radio that works fine. I was thinking or something that could use Crank/solar as alternative power source and in my searchers i saw this Radio
Any thoughts about it ? do any of you use it ? Any other suggestions ?
Many thanks
73 De VA2FCS
The radio I have does not have USB. It uses 4 AA batteries or wall adapter. I do have a Jackery 500 power station. I can plug the radio into it but that would trigger the inverter. consumer grade inverters have a 75-85% efficiency rate and top of the line inverters have an efficiency rate of 90-95% either way it sounds like a waste of power just to power a small radio. Power outage tend to happen during winter over here most of the it happens during freezing rain episodes. Last April I was out of power for 6 days. Fortunately I have a 120 Ah LIFEPO4 batteries to power my amateur gear. I am currently looking at Ecoflow products tu supplement the Jackery 500 I already have.If your radio can use a USB port, then one idea is the one I posted earlier, A Ryobi 18 volt inverter / charger with a good sized solar panel and several) batteries, I use mine (it has USB and 120 volt outlets) to power a (6 watt) light for reading), I got tired of wearing head lights.
I get a lot of power outages for some reason, about 5 days was the longest, 18 hours is normal, and 5 hours is pretty common. It's mostly for comfort that I use battery back up on things, I use a 40 volt Ryobi inverter (lots of battery powered tools/ lawnmower etc) to power a mid -size TV for the sake of sanity (for others, I like the books) (I can get quite a few over the air channels, and I've converted a bunch of DVD's to flash drive).
As far as the important stuff like the fridge, not yet, but thinking of a bigger inverter.
Joel
I already made the test with Duracell rechargeable batteries I already have and it lasted 24 hours. Did the same test using Eneloop Pro rechargeable batteries I just bought and got 27 hoursinstead of taking all that time to burn through a set of batteries, why not just measure the power your radio uses?
measure milli-amps with a multimeter, times voltage you get from the batteries equals mW.
for example, it's using 6 mA. your 4 batteries are all 1.4V so total voltage is 5.6V, that's 33.6 mW.
if you want to know how long the batteries would last, say that brand of batteries holds 2400 mAh. 2400/6= 71 hours.
Thanks, I will look into it.A very universal little "emergency" radio is the LiJiANi Rd239.
It receives nearly everything from MW up and has BT, ....
Just buy a bunch of batteries in bulk for whatever your favorite radio uses.
Or go cranking ...Just buy a bunch of batteries in bulk for whatever your favorite radio uses.
...so you can listen to some Clarence Carter.
They are often a Chinese copy of a Chinese copy of a Chinese copy ...So many of these radios appear to be identical, how do they perform?
in terms of sensitivity, selectivity, image rejection, power usage, audio quality, or what?So many of these radios appear to be identical, how do they perform?
