RadioFeed Error code 10
kb3nun
west pittston
Ok new sds200 with a new laptop no anti-virus installed with proscann 20.4 installed and atleast once a day the feed shuts down on the source side that connects to broadcatify and reads
Error code 10 - the operation is not allowed on non-connected sockets
Can't seem to track down the problem, I shut off all the windows firewall and windows defender and did an exception and the laptop in hardwired
Does anyone have any ideas
ProScan
Software Provider
Ontario, Calif.
Per the FAQs
Q: I'm using the Source Client feature to stream audio to Broadcastify. I'm experiencing intermittent dropped connections.
A: Intermittent connections could be caused by your computer, NIC card, cables, router, ISP, far end, etc. It has been suggested by a few users to use a tool called PingPlotter to isolate where the problem is.
Ensure you're not using AVG Anti-Virus software as that will interrupt TCP traffic.
If using the BCD536HP Wi-Fi, click the URL Audio Setup button and see if excessive Packet Loss shows in the dialog. Wi-Fi interference or a flaky Dongle could cause excessive packet loss. Move the dongle and scanner to another location to see if the packet loss decreases.
These links may be helpful.
BCD536HP WI-FI dropping issue
Feed keeps dropping out
Connection Issues
NCIC105
Somewhere over Georgia
I'm also getting dropped connections with
Error Code 10 - Unable to write data to transport connection. An existing connection was forcibly closed by the host.
ProScan
Software Provider
Ontario, Calif.
Did you see post 2 ? What did you do if anything to try to resolve this?
jaspence
Michigan
Why no anti-virus? If the laptop is new, the included Windows software provides protection. I have 6 computers at my location and use the built in protection with satisfactory results. Disabling it to check a problem is acceptable, but don't forget to restart it and don't waste money on a "trial" package that may come on a new computer and expire in a month or two.
ProScan
Software Provider
Ontario, Calif.
Sorry, been out of town..Just Windows antivirus...No source client...Unfortunate I don't have the older version...I cleaned out D/L's and deleted it...
You didn't answer my questions. I may delay my responses until you get it together.
Again, Did you see post 2 ? What did you do if anything to try to resolve this?
Did you try PingPlotter? I've heard of one case where PingPlotter traced the problem to the ISP.
Also try reinserting the Ethernet cables or use and use another port on the router or switch. If you have another Ethernet cable then substitute cables.
{edit} What do you mean by "No source client"? You're using that and that is where the error occurs. Right?
