What is up with all the capitals. It's annoying.
What about my post?
Re-read my post again. EVERYTHING IS LOGGED.
There is likely(most likely actually is) a saved template for the RID assigned to Oscoda County. Any affiliations to talk groups, or channel grants requested by that RID that are not programmed into the legit radio, are by default, his cloned RID. It is not rocket science to be able to figure out what transmissions are the legit radio, and which transmissions are not.
It was also a RID that was "of an infrequently used radio." It sounds like the radio was a 'cache radio' or something similar.
Everything apparently was logged except the voice traffic.
I think the evidence as presented in the consent is circumstancial at best. If it were a cache radio, it probably has most if the important TG's installed in it anyway. Who is to say there aren't two, or twenty cloned radios on that same ID? Was any audio recorded to bolster the evidence? Apparently not or it would have been revealed.
Usually these cases start out with a jamming complaint. In this case it started with a dodgy traffic stop, a warrantless search and property siezure, and the reverse engineering a circumstantial case of operating on the system.
It would be as if the FBI knew you had an unusual calibre weapon, of which only a handful had been made, they set up a sting to seize your weapon, then connect you to 10 murders using weapons of that same calibre, without any supporting ballistics evidence.
By the way, I ran across a YouTube video of someone explaining how to clone a radio on MPSCS, so there is that.
Sent from my SM-T350 using Tapatalk
