FCC seeking comments on allowing Garmin to produce GMRS/FRS with data beacon. Speak up to STOP this.
Hans13
Thank you. Does the Vertex repeater actually have receive capability to monitor the output frequency and enact BCLO when there is a simplex user on said output frequency? Since "... why are repeaters given a pass stepping on users who might be simplex on the outputs?.." was your complaint, that would appear to be required to solve the issue. If it will, that is much easier than adding an auxiliary receiver and the associated changes to do so with other brands.
Honestly, I do not know if it works that way as I have never enabled it. I have been told that is the way it works on that repeater; when there is signal on the output frequency of sufficient strength to overcome the squelch setting then the repeater does not transmit. That's how it was explained to me by more than one tech. They could be wrong. I have no personal experience using it since not doing so on repeaters is standard practice across the board in my experience.
Hans13
You get 675 and the simplex channels on your license plus a repeater pair if you want it and get the coordination.
Goodness no to coordination. That is a mess we do not need in GMRS. The frequency parking, the power grabs, the butt kissing. That, IMHO, is a terrible idea!
I prefer leaving GMRS as it is right now; perhaps adding DMR and clearly allowing Part 90 radios and repeaters. FRS data bursts, as described in the proposal (which I still have not read yet) doesn't concern me a bit.
Hans13
Wow, it just dawned on me that the duplexer would notch out the output frequency so it likely works as you were describing. I withdraw the assertion that repeaters now can listen on the output and inhibit transmission if there is signal on the output frequency.
However, that does not change the fact that, per the regulations, repeaters should not be interfering with simplex traffic anymore than simplex traffic, per the regulations, should be interfering with repeater traffic. Again, that is the way it is written. Technical shortcomings of the repeater equipment do not negate the way the regulations are written. And THAT was my original point and not the abilities of repeater equipment; the regulations do not provide for a repeater to interfere with a simplex communication. There is not priority. as far as I am aware, in the language of Part 95.
In reality, exactly how it is now is fine with me regarding priority. I have no problem when a repeater interferes with my simplex traffic as there are enough alternative channels for me to use. On the flip-side, with the way the regulations are currently written, I do not support the complaint that these data bursts shouldn't be allowed the same latitude that repeaters are allowed with no written exception for those repeaters. I was preferring BCLO on those data bursts and would've supported that requirement and am glad to now see that it was already in the proposal. In short, I believe it to be hypocritical to condemn the proposal because of potential intrusion into other simplex traffic whilst repeaters are ignored doing the exact same thing with no exemption written for them in the regulations.
W8UU
Pilot of the Airwaves
Wellston Ohio USA
The fix is to segregate repeater operation to their own frequencies and establish simplex-only channels within the existing GMRS channel structure. Then coordinate and license the repeaters and eliminate linking these gargantuan GMRS networks together. Nothing like getting your local GMRS simplex traffic obliterated by two guys halfway across the country having a yak-fest that pops up out of the blue on your local networked repeater. That isn't what GMRS was ever supposed to be. And FRS operating in overlay fashion with GMRS frequencies should have never happened. Move FRS somewhere else. This proposal would require new GMRS units to be incapable of transmitting on split frequencies for repeater operation. Instead, they are simplex. A simple manufacturer programming issue. Nothing else needs to change. Many problems solved with one FCC action.
Hans13
I completely disagree.
K6GBW
Montebello, CA
For the love of God, please no DMR on GMRS! When two transmitters key up at the same time you get signal collision and the data stream is corrupted. The end result is that receiving stations hear NOTHING. At least with NFM you can hear the stronger station and you know there was a second station there. It's simply more usable than DMR. When my agency switched to digital we had to learn that the hard way.
Hans13
Lack of the benefit of FM capture effect with DMR is a good point; essentially all or nothing with DMR. Still, I currently support changes to allow mixed mode, FM and DMR, on all of GMRS.
Hans13
The chances of these Garmins flooding the GMRS frequencies are slim . The price alone will prevent the majority of people purchasing them.
Yep. Exactly. That coupled with the busy channel lock out and interstitial channels only requirements of the proposal makes this a tempest in a teapot; a really insignificant issue, IMHO.
