SDS100/SDS200: Forgot How To Personalize Startup Screen SDS200
kudzu_kid
Emperor
Oooooohhhklaaahomaa
Hi There!
Well, it seems the ravages of old age are upon me. I can't remember how to 'personallize' the startup display using Sentinel. I used to have my Amateur callsign and email address when the SDS200 first powered up, but I noticed recently it wasn't there (maybe an update killed it? IDK). How do I edit/append the startup screen in Sentinel?
Many thanks!
fxdscon
¯\_(ツ)_/¯
Hi There!
Many thanks!
If you just want to change the text only on the startup screen, use the profile editor in Sentinel and select the "Display Options" tab, type what you want in the "Opening Message" section, then write to the scanner.
For a custom Opening Graphic Boot Screen For The SDSX00 Scanners, use a graphics editing program to set these parameters for an existing image, or create your own...
(1) The image must be in the .bmp format (you can't just change a jpg or png file extension to bmp, it must be "saved as" a bmp format in a graphics editing program).
(2) The image must be named opening.bmp (lower case only)
(3) The image must be at 24 bit color depth (16 million colors)
(4) For use in the SDS100 the image must be exactly 240 x 320 (width x height)
(5) For use in the SDS200 the image must be exactly 480 x 320 (width x height)
(6) The image must be placed in the BCDx36HP Folder on the scanner's SD card (same location as the profile.cfg and other files). Use Windows File Explorer with the scanner in Mass Storage mode to transfer your image to the SD card.
If even one of the above parameters is not correct, the scanner won't recognize the graphic at all, and will boot up with whatever text was there previously.
Once the graphic is in place on the card and working, it won't be overwritten by any "writes" from Sentinel to the scanner, regardless of what the "opening message" text is set to in the Sentinel Profile Editor. The scanner will always boot with the graphic if it's set with the correct parameters, and in the correct location on the SD card. Reformatting the card or using the "Clear User Data" function will, of course, delete the custom graphic from the card.
To change back to the original opening screen text, just delete the .bmp graphic file you put in the folder on the SD card, and restart the scanner.
kudzu_kid
Emperor
Oooooohhhklaaahomaa
Had to re-read this - but yes, I just want to add text. Perfect! Thanks! Wondering how/why it ever disappeared after I added it and it worked great for quite a while. Thanks for the hep! Appreciate it!
