Just wanted to give a little explanation to this system and issues monitoring. This is in fact a Linear Simulcast Modulation (LSM / CPQSK) system. What that means is that all of the towers are broadcasting the exact same data at the same time. The Harris radios that work with the system are set to only listen to whatever tower they're closest to. The problem with any scanner is that it hears all of the towers that are close enough to your location simultaneously. The scanner ends up hearing the data from multiple towers at a slightly different time and it has no idea how to decode that. (Think of being at a indoor concert and hearing the sound coming from the stage and the backwash off the walls at the same time) Because of that, the scanners (even the new ones) aren't able to figure out the signal clear enough to decode it. The only way to overcome this is to do one of two things. 1. Get your scanner near 1 tower only. (you can look on RR and see the actual tower locations I believe) 2. get a YAGI antenna for the scanner and point it at 1 tower. I have tested things and when close to a tower, my BCD396XT decodes this system flawlessly. The problem is that I don't live next to a tower. Bottom line, if you want to monitor this system with a scanner, you have to be near a tower site or get a YAGI directional antenna. The problem with this system isn't lack of signal, it's actually an abundance of signal that arrives at the scanner milliseconds apart.
